Results 1 to 9 of 9
Thread: EL34 v KT88
    I'm Shaun.
    Default EL34 v KT88
    OK, a small review/comparison between my stock EL34 valves and Johnjo's borrowed set of JJ KT88's
    Where to start...?
    Treble
    Really improved level of detail in the high frequencies with masses of control and precision. No glaring brightness as there was with the EL34's which I have to say bordered on hardness and glare. KT88's really are a massive improvement
    Midrange
    A really laid back midrange via the KT88's in which it is so easy to hear the stop and start of synth pads on George Michael's Older album. It is also much easier to hear the multi layering of synths as well. The stereo effect with the KT88's is truly massive and much better defined but vocals now sound more distant which adds a degree more depth. On Bowie's Blackstar the drums/drum machine is extemely tactile with an easy to hear skin decay on the lower frequency drums. The midrange has much more 'pop' to it in a propulsive way
    Bass
    The bass extends about another octave and this extra bass is really obvious but in a well controlled way. Very tight, extended bass just the way it should be. Much more propulsive than with the EL34's with amazing clarity and power
    The KT88's have amazed the most with their phenomenal detail and resolution
    Incredible really
    Massive thanks to Johnjo
    CAMBRIDGE AUDIO CXC CD TRANSPORT INTO AUDIOLAB M-DAC - PRIMA LUNA PROLOGUE THREE PREAMP - PRIMA LUNA DIALOGUE PREMIUM POWER AMP - SPENDOR S3/5R2 LOUDSPEAKERS - ATLAS HYPER INTERCONNECTS - TELLURIUM Q BLUE LOUDSPEAKER CABLES - ATACAMA STANDS - PRO-JECT SUPPORT PLINTH
    I'm John.
    Glad you're enjoying them Shaun
    I'm Shaun.
    Well, having tried the KT88's for a week or so now, I have noticed little squeeks and warbles and farts emanating from the system on power up and power down so my only conclusion is that maybe the natural choice for my amplifier is the original EL34's. Having put them back in the power amp everything is now back to how it used to be and sounding very quiet. I'd still love to thank Johnjo for the loan of the KT88's though as without his generosity I would have had no knowledge without actually buying a set.
    I'm Neil.
    5881 are worth a try too, if your amp will take them without an adjustment, 6L6 also interesting alternative as well.
    Regards Neil
    System 1 (Living Room) : AMG Giro turntable, AMG 9W2 tonearm, Air Tight PC3 cartridge, Passlabs Xono phonostage, AMG Reference armcable. Marantz CD7 CD player, Sony HAP Z1es Digital File Player + Audioquest Jitter Bug, AMR DP777 DAC + HP laptop + iFi Audio i power, Wireworld Starlight USB + Audioquest Jitter Bug, for computer audio, Audio Valve RKV2 headphone amp, headphones Grado GS 1000, Nakamichi CR5e tape deck, Balanced Audio Technology VK300se integrated amplifier, Anthony Gallo Reference 3.1 speakers. Cabling: Signal - Atlas Mavros, Audience AU24, Speaker - Atlas Mavros. Mains Cabling: Audience AU24, Analysis Plus, TCI. Mark Grant distribution blocks, Equipment tables Target Audio B series.
    System 2 (Music Room) : Loricraft Garrard 401 turntable + SME 5 tonearm + VDH MC10 cartridge + Graham IC70 tonearm cable, Modified Technics 1200 turntable + Triplannar 7 tonearm + VDH Frog Gold cartridge + Paul Hynes SR7 PSU, SME Model 20 turntable + Graham Phantom tonearm + Ortofon MC5200 cartridge + Graham IC70 tonearm cable, Balanced Audio Technology VK10se phonostage, Moon Andromeda CD player, Esoteric P5 SACD transport and P 5 DAC, Toshiba 9500 DVD Audio player, AMR DP777 DAC + Dell Laptop + iFi Audio i power + JKenny JKSPIDIF + Wireworld Starlight USB - for computer audio, Kenwood 8300 tuner, Revox B760 tuner, Magnum Dynalab signal sleuth, Leak Troughline tuner + EAR Stereo decoder, Revox B77 mk 2 & Revox A77 mk3 reel to reel recorders, Balanced Audio Technology VK52se pre-amplifier, Music Reference RM200 mk1 power-amplifier, Anthony Gallo Reference 3.5 speakers. Cabling: Signal/Speaker - Audience AU24, XLO Type6. Mains Cabling: Audience AU24, TCI. Mains distribution blocks Mark Grant and Russ Andrews, Equipment tables Clear Light Audio.
    I'm Peter.
    Your amp sure does have a lot of valves! If you ever get the chance, try some KT120 valves. I preferred them to the 88s, seeming to me to be a 'best of both worlds' solution.
    Ping Pong Aficionado
    I'm John.
    Quote Originally Posted by petrat View Post
    Agreed, or KT150s which this amp will also take.
    Shaun, did you flip the bias switch for the KT88s?
    Don't think you can blame squeaks and farts on the hifi
    I had one KT88 based amp, I think it was a YAQIN MC-100B integrated, and for some reason I didn't get along with it at all
    Strangely for a valve based amp I found it rather harsh sounding but I don't know if it was that particular amp (Chinese made of course) or that I am used to the SET sound but it just didn't gel with me
    I have to say though that the amp was fantastically made and a really heavy lump
    Bev
    Naim CD5XS Through:Black Cat Silverstar 75 To:Naim Dac Through:Naim 5 Pin Din To:Supernait 2 Through:NACA5 To:Living Voice Auditoriums or Rega RS3's or Magneplanar MG1's
    I'm Shaun.
    Yeah, flipped the bias switch on the side of the amp but there were just too many electronic noises for me to ignore them. I think that for the time being I shall stick with the original EL34's simply because they aren't even run in yet and because they have always been my favourite valve. I appreciate that there is a huge gulf of difference between single ended and push pull or at least there has been in my past experience. My ultimate amplifier type would be 300B single ended but this is the real World and such things are simply not practical but at least I have owned a few of them in the past. I hate Chinese amplifiers with a passion. I have wasted a good deal of money on Chinese amplifiers and CD players and like most human beings, I learn from mistakes.
    I'm John.
    These are a new matched quad Shaun and were dead silent in my amp, wonder if there is an issue with your amp
    I'll try them when they return and let you know
