This is all very interesting but doesn't really answer my question - maybe there isn't a simple answer. Can i put it another way? I like these cables in my headphones so when I saw them going cheap I bought a few to make some cables with (but keeping 2-3m with the mini coax end for shorter headphone cables). Will they be any good or am I doomed to failure? Any chance they will make good speaker cables alternatively?
http://pages.ebay.com/link/?nav=item...d=271903509936
Oops
Yes, but it isn't an insulator then. Conductive plastics are sometimes used in mic cables for screening, but they aren't being used as insulators in that application and require an additional insulating layer.
My original comment stands - the insulation on interconnects doesn't screen them from RFI.
They look a bit thin (and short) for speaker cables, but they would work.
[QUOTE=RothwellAudio;820921]Yes, but it isn't an insulator then. Conductive plastics are sometimes used in mic cables for screening, but they aren't being used as insulators in that application and require an additional insulating layer.
Doesn't stand, hybrid cables with multiple layers, nowhere did I say single layer cables, and it was you that mentioned insulator, I didn't .
Don't twist word to your own definition.
My comments stand
