I seem to have won a Denon DL-103 with a boron cantilever and Shibata diamond - http://www.ebay.fr/itm/122282142943
I was not expecting that.
Kevin
I'm Allen.
Sure is a looker how much original 103 is left ?
Not much....
Kevin
Oops indeed
You'll enjoy that Kevin
Love it - well done! I just hope it likes your FXR...
I'm Charlie.
Very bling
Will be an interesting start to the New Year
No worries, Kev. I don't think you'll need 18g though, as the new gold body-shell will be considerably heavier than the stock plastic one it replaced, so you'll have to take that into consideration.
To that effect, you don't really want any more than said 18g mass *in total*, including the weight of the cartridge itself and 'headhshell' of the FXR, or you could end up with a somewhat 'sat on' and over-damped sound.
If that ends up being the case though, just use a lighter headshell weight. My advice would be firstly to install the cartridge as is and see how it sounds, then if necessary experiment with adding mass from there, obviously ensuring that you have the ability to balance out the weight at the other end
Anyway, hope it hits the spot for you!
VTF at 2.5g, and sounding pretty good.
Kevin
