Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Garrard 401 Transit Screws
    I'm Neil.
    https://www.google.co.uk/search?q=ga...DpvV2SEITMM%3A
    On this pic you can clearly see the left screw is under the cutout near the spindle. The right one should be too if hole is big enough. You might get a thin driver up the side from bottom for you to track it from top.
    Yes that could be it.
    If a 401 owner can confirm that then, that's a simple job.
    Regards Neil
    I'm Neil.
    Took a chance Grant and that is them. Undoing by turning anti clockwise lowers the clamp
    Regards Neil
    good job Neil. Sounding good i hope
    There is a slight sound advantage to removing the transport bracket altogether
    dont forget to clean the idler gear, clean and polish the inner rim with autosol and oil the points indicated in the picture below
    garrard idler wheel shot by Alan Towell, on Flickr
    Alan
