Results 11 to 20 of 21
Thread: Mains Distribution Unit
    I'm Ken.
    Aye, its a close thing on price, cases are not cheap if you do a diy job.
    I would have preferred a deeper case (front to back) as the short one means you can't stack things on it.
    Look out for one of these
    I'm Ken.
    Interesting... ive got the belkin purav unit and didnt find that with it. Not tried system without it for a long time of course, must try that sometime actually
    I can't comment on other units, but this basic Furman is the pits for sound quality, made Grace Jones "Nightclubbing" on vinyl sound flat, when it is a very dynamic album.
    I'm Richard.
    Oh dear, I have one of those Pure AV units after lengthy advice on these forums some time ago. Are we now saying they are a waste of time and money?
    (I know, I should do an A/B comparison...)
    Im not... i like mine
    I'm Gary.
    Ken,
    go balanced mains!
    Stick the BMU unit in another room or cupboard and run some meaty soliid core spur mains cable from that through a drilled hole in the wall into a hard-wired 'hydra' in the listening room...
    Can all be hidden out of sight.
    hardcore, maybe, but short of a dedicated CU to your hifi the next best thing imo.
    Didn't get on with mains filters tbh, not bad for sources but sucked the life out of amps I found.
    Didn't have the big beastie Grant has, know a lot of folk liked them.
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
    I'm Hugo.
    Some years ago I was tempted to buy an Olson 'Sounds Fantastic' distribution block that incorporated an inline filter module and a screened input cable. Guess what? It sounded awful - very much reflecting your experience here. So, I ripped out the filter, replaced the inout cable with an old unterminated Kimber Powerkord that was lying around, and while I was at it, replaced the internal wiring with solid copper stripped out from ordinary twin and earth and insulated in teflon tubing. Result? Dynamics were back and the music with it.
    This made me think that any form of inline mains power filtering is musically destructive. I've heard Isotek demonstrations where they went from no filtering, up the range to very extensive designs, and in every case I heard a progressive sweetening of the sound but with a progressive penalty in dynamics and musical interest. A few years ago I bought a Belkin PF30 following forum enthusiasm and it did the same - awful squashed effect on musical dynamics, but it did work well on the telly. A Tacima block was worse, and now powers my home broadband setup, in the hope that it will stop some or all of the switching PSU noise from squirting back into the rest of the house supply.
    For anyone with mains problems, my advice would be to experiment with simple plug-in parallel filter devices; and if the problems are really bad, do as Gazjam suggests and look at balanced mains solutions, or for the wealthy a PS Audio Power Plant.
    The annoying thing is that, according to objective electrical theory, none of this should make a difference, but sadly my experience is that it does.
    Quote Originally Posted by Qwin View Post
    I tried the Furman unit in my system last night as a dry run for a couple of bake off's that are coming up.
    Aauughhhhh!
    Sounds bleedin awful. I had to double check I had everything connected correctly.
    The midrange sounds clean and transparent, but I have lost all the dynamic range.
    The description, that these things just suck the life out of the music seems appropriate.
    Left it running for 24hrs, in case something needed burning in, but it made no difference.
    I am now in the process of bypassing the filter circuit board so the box will then be just a straightforward distribution unit, which is all I needed in the first place. My advice would be to buy a case, a switch and some IEC outlet strips and make a basic distribution unit yourself. A proper balanced supply is a different prospect, but I certainly would not recommend these filtering units.
    Oh well, nothing ventured and all that.
    I'm Ken.
    Gaz - I initially didn't think a balanced supply was feasible for me, because of space limitations.
    However, your idea of putting it in another room has merit as I already have a desk top computer and the air pump for my linear tracking tone arm in the next room. I installed some 22mm dia plastic tube through the wall to help the cables for these slide through. The desk top computer is no longer needed so I have spare capacity to run the PSU cable through.
    Longer term this will now be my goal, a balanced supply in the next room feeding my distribution unit at the bottom of my rack.
    Thanks for the tip.
    I'm Ken.
    Ammonite - When I read various reviews about these devices, there were folks for and those against, so for not a great outlay I gave it a whirl.
    Like you, I found the results from this basic entry level item disappointing. I can't say about items further up the range, but I would be doubtful now of anything just claiming to be a filter.
    The 60mm square PCB inside my unit, is now being used solely to power the "ON" LED.
    I'm waiting for a couple of bus bars to arrive through the post, I'm joining all the outputs to the switched input and just passing the power through the unit unmolested.
    Its still a useful item to me, purely as a power distribution unit, keeps my cabling tidy and short and a single easily accessible switch to isolate everything at the end of a session is handy. My added Volt/Amp meter will work as before. The plan is now to eventually build a balanced supply and feed this distribution unit from that. Lots of other things to complete first though.
    I'm Gary.
    Thanks for the tip.
    Nice one Ken.
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
