Results 1 to 6 of 6
Thread: Bluetooth and aptx
    Default Bluetooth and aptx
    Do any of you have views on Bluetooth and apt-X, which is now being deployed for some speakers and headphones?
    https://www.aptx.com/how-it-works
    https://www.cnet.com/uk/news/can-apt...ver-bluetooth/
    I am slightly sceptical that it would provide better results than a really good wired set up with good speakers etc., but I suppose one has to consider what the alternatives might be. For people who are perhaps used to listening to computer speakers, then it may indeed sound much better.
    A couple of speakers using this technology at Richer -
    Wharfedale Diamond A2 - http://www.richersounds.com/product/...ar-diam-a2-blk
    Dali Zensor 5 AX - http://www.richersounds.com/product/...-zens-5-ax-blk
    Dave
    I'm Will.
    I use a denon bluetooth portable speaker, in conjunction with Samsung S4, both are aptx compatible, and the SQ is vastly better than my previous non aptx portable (big jambox)...
    I also have a QED bluetooth receiver (again aptx) linked by toslink to my MDAC (useful for when ones friends want to play something from their phone etc.), streaming FLAC from a mobile sounds pretty good, until you compare it to the USB input from my SBtouch, of the same FLAC track...bluetoth/aptx sounds around high end MP3 to my ears (rather flat), and add to that the occasional dropout...
    So I'd definitely recommend it for the portable/convenience market, however for more serious applications I think ultimately bluetooth is compromised by its bandwidth, aptx just improves upon its mediocrity...
    Cheers, Will
    Think Naim are using it in one of their magic boxes. Not tried it myself but supposedly lossless.
    I'm Justin.
    I use it in the car. I've tried it in the main system and I agree with WAD62, basically.
    I'm Will.
    Quote Originally Posted by User211 View Post
    That's one problem with the aptx site (or me perhaps), I can't find a list of car audio systems that support it...I currently run mp3s off a USB but would prefer the FLAC bluetooth/aptx route from my phone...given mp3s sound markedly better than bluetooth on my DS3's stereo I can only assume mine doesn't support it...
    Cheers, Will
    I'm Will.
    I think due to the compression/decompression algorithms, at each end of the bluetooth connection, it's supposed to be able to carry 'full CD bandwidth', but I suspect due to the additional A/D/A conversion gubbins going on in the chain there's got to be a downside...or at least that's what it sounds like to me.
    However perhaps my Samsung S4/QED receiver combo is not a good reference point...
    Cheers, Will
