Results 11 to 20 of 25
Thread: Rogers LS3/5A restoration
    I'm Martyn.
    Where do you live ?
    I am Nr. Oxford.
    Martyn.
    I'm Ian.
    I'll pm you
    I'm Ian.
    After a couple of days filling/rubbing down/painting/rubbing down/painting etc I've got the backs repaired. It wasn't just the removal of the spring clips, there were a lot of bad scratches on the backs.
    From certain angles and light conditions you can just about see the repair but generally I'm happy with the result and at least it's now airtight!
    I'm Martyn.
    Quote Originally Posted by ianlenco View Post
    Superb repair.
    Well done !
    By the way, those terminals look just right
    I'm Ian.
    You're very kind Martyn. Have to try and reattach the Rogers labels next then replace the internal foam - kit is on its way from Falcon. So should be finished the restoration in a couple of days.
    I'm Adrian.
    Wow. This is why I sold them - I could never have done such a good job. If the old guy who gave them to me could see the work going into them he'd be amazed. I doff my cap...
    Adey
    Sent from my Aquaris E4.5 using Tapatalk
    Technics SP10 mk2
    Miyajima Shilabe cart
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
    Audio Note ANe-SPX speakers
    I'm Ian.
    Foam arrived today. All cut to size so an easy fit - loose fitting below.
    So, solder the crossovers to the speaker sockets, attach the tweeter grilles and wash and fit the speaker grilles.
    That apparent blob on the grille is just a light anomaly.
    Finished! They're playing and sound even better. Odd thing is they go louder without distress. I assume now the cabinets are properly sealed there's more back pressure on the mid-bass units so they work better :undecided: Voices are so lovely
    I'm Deano.
    Well done they look brand new and i bet they sound fantastic, good job mate!
    Sent from my LG-H961N using Tapatalk
    I'm Ian.
    Thanks Deano but close up there are still a few marks that show they are definitely not brand new! Adds a bit of character You're right about the sound though.
    I'm Timothy.
    Really nice work on the repair. It totally boggles the mind why someone would do such a botch job on a great pair of speakers, wow. Nice to see them being taken care of properly and bringing them back to such a nice condition. Well done!
    Holbo TT-Nag 110-Croft phono/Innuos Zen MK2/LinnenberG Telemann DAC-Preamp/LinnenberG Allegro monoblocs/Duevel Venus/LinnenberG Maestro SE-Senn. 660S DH Labs cabling
    Croft Series 7 amps, WLM La Scala, Naim Uniti1, Naim Nait XS3, Naim ND5XS2, Guru Junior
