I was wondering if using a step down transformer with power amps might be a bad idea. Have my eye on a Japanese power amp with an industrial sized step down transformer. Would this hinder dynamics?
Adey
Sent from my Aquaris E4.5 using Tapatalk
Adey
Technics SP10 mk2
Miyajima Shilabe cart
Hashimoto HM-X SUT
The Truth linestage
Cary 805c SET amps
Audio Note ANe-SPX speakers
Absolutely not. It will be fine.
Or not, industrial size transformers have a tendency to make mechanical noice.
I'd personally seek a way co convert it to take 230v as i wouldnt want the extra bulk but thats just me!
Make sure you use a decent transformer, ie; the step down should have a seperate primary, and secondary winding, therefore; its also an isolating transformer, and not an Auto transformer, which has one winding, which is tapped!
A...
Nikola Tesla
www.tubedistinctions.co.uk
Matthew 5:10
I must say that I can't see any problem with an autotransformer here..... It's the most common solution.
Nikola Tesla
Matthew 5:10
Thanks guys - the problem is I don't know what type of transformer it is - only that it's huge and has one cable going in and one coming out terminated in a double UK socket as it's feeding two monoblocks configured at 120v for the Japanese market. The seller can't give me any concrete info on the step down - he said to either use it or wire the amps in series... scratch..
Adey
Technics SP10 mk2
Hashimoto HM-X SUT
The Truth linestage
Cary 805c SET amps
In principle there is nothing wrong with wiring the two monoblocks in series for use on the UK mains supply, but it might invalidate your home insurance.
One of the advantages of using monoblocks is to be able to locate each one close to the speaker it supplies. This configuration would make the series mains connection complicated.
I,d be inclined to give it a bye tbh. Might just be more trouble than its worth
I was thinking the same....
Adey
Technics SP10 mk2
Hashimoto HM-X SUT
The Truth linestage
Cary 805c SET amps
