look pretty good to me. not seen any i wouldnt give houseroom to
It measures as state of the art for a valve power amp in 2016.... and was designed early '60's! Respect due to Mac electronic engineers if not stylists....
The yank answer to Radford in terms of THD, bandwidth, damping factor etc.
I had a MC225 many years ago and was not overly impressed. They are rather like Harley Davidsons, in that they have built a reputation through skilful marketing but are not really that good.
I'll agree on the HD's! The MC225 I'd never come across but the specs are excellent and there are rave reviews elsewhere.... one man's meat?
I'm Slav.
As with every audio component is a matter of personal taste , I used to own AR Reference 110 and couldn't get on with it , probably bad amplifier-speakers combination .Prior to MA2275 I had MC402 and in my new little room it was little bit too much , swapped for Manley Snappers and they didn't click , finally went for 2275 and it was it , it must been 7 years since and no itch for change .Audition is a must , is hard to advice without knowing your preferences and accompanying equipment , matching specs to your preamp and speakers would be my first step .
I'm Shane.
Slav,
Is the 2275 auto-bias?
S.
I'm Slav.
Yes , output is self-biasing , you can also use KT88 or 6550 .
Since I bought it I had one failure but it was my fault , I bought tubes from China , didn't think about testing them and they blew protection resistors and transistor .I ordered all parts through McIntosh , received within couple of weeks and it cost just few £ , apart from that nothing ever happened .
MA2275 sports fairly decent MM (47k , 47pF) phono stage as well ( 2x Ecc83) , amplifier is rated 75W but measures close to 90W ,
volage amplifier based on 2xEcc83
phase splitter 2xEcc81 - I do prefer 6201 from Valvo(Amperex,Philips)
2,4,8 ohm speaker taps
you can ran it from separate pre-amp if you wish
one thing to remember and it applies to all tube amps damping factor is quite low(greater than 18 published)
I'm Slav.
Real life photos , meter back lights on and off , not the best quality (mobile phone)
I'm Slav.
Shane, if you travel this way in the future you're welcome to pop in and have a listen , mind you I'm on holiday till 16th of January and working mostly away from home so I'm afraid weekends only.
I'm Shane.
Stunning looking amp!
I'm not very keen on travelling much, thanks to my dodgy ankles! Also, I don't drive either.
But thanks for the invitation, Slav.
S.
