Results 1 to 10 of 17
Thread: Moode help please
    I'm Bill.
    Default Moode help please
    I have just set up my new Pi 3 with Moode, trouble is I can't seem to be able to mount my USB Hard Drive. I have it plugged into my router and can confirm it is showing on the network.
    In the 'Music Source Configuration' tab I have pressed 'Update MPD DB' but no USB drive is showing.
    Any pointers would be greatly appreciated.
    Cheers,
    Bill.
    Have you tried it plugged into the rpi? Into the router I think it would become a nas maybe..
    I'm Bill.
    I beleive connecting directly to the Pi has a detramental effect on sq, not sure? Not tried, but will give it a go.
    Quote Originally Posted by Bourneendboy View Post
    sounds ok to me Bill, but it might. If its not directly connected then I would think it would become a nas and need set up that way(I could be wrong though) ive always ran mine direct from usb. should be enough power there with the newer psu, although Ive always used a self powered hdd.
    I'm John.
    If you try connecting directly to the RPi you may need to enable 'Max USB current 2X' in the system config.
    The sound when connected directly seems fine. Attaching the HDD to the router didn't work very well for me.
    I'm Bill.
    I cant even get on the Config settings now!
    I'm rupert.
    check the ip and the path to the folder containing the music... if not correct the music wont show in mpd
    I'm rupert.
    Quote Originally Posted by jonners View Post
    You may need to enable 'Max USB current 2X' in the system config.
    the drive is on the network AFAIKS
    I'm Tim.
    Cheers,
    Bill.
    Hi Bill,
    Need to know a few things then u should be able to create a new NAS source.
    1) Name that show up on your network
    2) Label assigned to the USB drive
    3) Path to folder containing music files
    -Tim
    I'm Bill.
    Quote Originally Posted by TimCurtis View Post
    Hi Bill,
    -Tim
    Tim,
    Thanks for your offer of help.
    1. BTHUB4
    2. usb1
    3. Music
    I've tried loading this info into the set up, but the page won't reload on trying to save. looking at my 'BT HOME HUB MANAGER PAGE' I can see the Pi keeps disconnecting.
    Cheers,
    Bill.
