I'm Slav.
That's 'cos you went about it the right way. You simply cannot use a ZYX (or any other good MC) into an inadequate phono stage or even worse, a cheap SUT.
I'm Slav.
Try to dial in VTA now , there is a horizontal line near the bottom of cartridge, keep it parallel to the record surface instead of trying to line up your arm , at 2grams it should bring SRA to 92 degrees (in my case half degree below).If you have azimuth adjustment is worth to try as well , when you get it right it improves channel separation.
Enjoy
VTA is perfect if judging by the line on the cartridge. A fluke more than judgment and azimuth seems to be rather close to perfect too. I am now tracking at 2g and I think the fine tuning has made a difference. Channel separation is amazing, bass is slamming so much my door is rattling and everything just seems to be working. The 220ohm loading sounds better than any other I've tried too. This cartridge is top class. Pulled out an album I haven't played for about a year and it's so good now. Didn't sound bad before but now it's really good.
I've been using a Zyx R50 Bloom for quite a while now and I agree that it is an excellent cartridge. Previous cartridges include the more expensive Kontrapunkt B and Lyra Lydian beta but I think I prefer the Zyx because it's so unfussy and natural. Totally agree that it needs at least 2gm tracking force and it is sensitive to VTA - not in a bad way but you can tune in a bit more bass or treble if you want though I prefer it flat. Excellent choice Oliver!
