If there is nothing in the signal path, whats to settle in, bar the listeners ears.?
I would still think cabling, solder etc, but as there is virtually nothing on this design I have no idea really if it would benefit from run in. I personally think passives can cause issues and spotlighting and tonal thinness are among those issues.
Done a search and the lack of anything out there regarding this, even the makers single page is woefully inadequate in my opinion. According to a thread on Audio Karma lack of gain can be an issue
And according to the maker, using it, it gets better.
Regards Neil
'Spotlighting'?
Again this could be the case of increased transparency showing up colourations further up the chain. There's no reason a passive would be the cause of this, it should be more faithful to the source, at least in theory. Not had this issue with any passive I have tried.
It needs mains power to work but if there is nothing in the signal path it can't be adding any gain, which makes it passive, doesn't it?
