Page 4 of 22 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 211
Thread: Waiting for the Truth
  1. #31
    Sure it will look a lot better for it. No keen on these boxes that not only show every touch but its difficult to remove them too. Wood cheeks are great, ive few things with them
    I'm Adrian.
    The intention is for it to mimic the Vida, only a little bigger. It's strange how I feel about it - there's something 'unbelievable' about it - I can't explain it. If I was in the UK is def bring it to some bake-offs for others to experience.
    In perpetual pursuit.
    Technics SP10 mk2
    Miyajima Shilabe cart
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
    Audio Note ANe-SPX speakers
  3. #33
    I'm Adrian.
    Update. After a long weekend of spinning vinyl of all genres I still cannot form a concrete opinion. Yes it has stripped away all veils, yes the detail is glorious - but I think I've lost a little musicality (colouration?) and there's a slight hardness in the mid that wasn't there before.
    Now, as there isn't a single component in the signal path I have to assume that by lifting the veils a slight colouration has been highlighted somewhere else in the chain. To confuse the matter more im also having to use a 1m Cardas Neutral Reference from Vida to Truth as my Cardas Golden Presence is too short (will be up for sale shortly) at 0.5m. So the new cable might be adding to the sight hardness.
    Of course it might also be highlighting a slight loading issues or even an SRA issue - it's that forensic.
    It's bizarre that something sonically 'invisible' has changed the character of my system. scratch
    Technics SP10 mk2
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
  4. #34
    Have you tried testing with digital, see if the same result happens?
    Also what does this thing cost? I have searched all over for a price, no-one seems to mention it so I am guessing it is a lot.
  5. #35
    Quote Originally Posted by farflungstar View Post
    Now youve got used to changes, it will affect how you hear things i guess.. you,ll have to develop a new way of appreciating music. Totally sonically clean
    There shouldn't be any hardness, though. Hardness in the sound is distortion that shouldn't be there.
  7. #37
    RothwellAudio Guest
    It says $975 here
    http://www.thehornshoppe.com/the_truth_pre_amp.html
    To be honest, those specs seem a bit odd. 60MHz bandwidth? But there's no mention of voltage gain, max voltage swing, THD etc.
    As I mentioned earlier, I would love to see inside this thing.
  8. #38
    It says $975 here
    Cheer. Read all that before and missed it. So with shipping and customs about a grand sterling, maybe a bit less. Not an unacceptable price, a bit much for me to take a punt on unheard, though.
  9. #39
    RothwellAudio Guest
    I agree. And as for "stripping away veils", surely the only veils that it could strip away are the ones that were imposed by the previous linestage. It can't strip away veils from elsewhere in the system.
  10. #40
    True, but if it is more transparent it could be showing up a problem that was previously masked, as Adrian suggested.
