Hashimoto HM-3 SUT
Hashimoto HM-3 step-up transformers in high quality box.
Bought this recently from a member of this parish.
These world-class Japanese transformers are switchable between 20x and 40x gain, giving cartridge loadings of 100 ohms and 30 ohms respectively. The 20x setting is perfect for most low output moving coil cartridges, such as Audio Technicas, Denons, Ortofons, Lyras, Transfigurations, Koetsus, etc.
The 40x setting will work well with an Io and low output SPUs for example, making this a very versatile bit of kit. The internal wiring is Audio Note silver, as are the rca sockets. The unit also has a 'ground lift' switch and vibration-isolating feet. The Hashimoto transformers are shrouded in mu-metal cases, and with the additional metal outside casing, they are almost immune to 'hum pick-up' from external souces (no problems at all ime). The unit is built to a high standard, and was originally created as a prototype for a commercial venture. Sound quality is top-notch, with dynamics, detail and tonality that few can match.
I'm only selling this as it's not an ideal match to my cart, which has a slightly unusual internal impedance for a LOMC, otherwise there's no way I'd be letting it go.
Looking for what I paid - £500 plus postage.
Hunter S Thompson
