Not knowing a lot about compliance and effective mass, my question is does 25 grams total mass for cartridge (9g) and headshell (16g) sound ok ? (no pun intended)
A lot will depend on which cartridge you intend to use.
Ralph.
I already have the cartridge - Ortofon Quintet Black and use it the the very light weight ADC LMG1 Magnesium headshell to good effect, which is a mere 7grams.
The reason for the thread is just curiosity really as I like the ADC headshell and just toying with the idea of trying another headshell in the future - maybe.
The QB's specs are:
Technical data
Output voltage at 1000 Hz, 5cm/sec. 0.3 mV
Channel balance at 1 kHz < 1.0 dB
Channel separation at 1 kHz > 23 dB
Channel separation at 15 kHz > 15 dB
Frequency range at - 3dB 20 - 25.000 Hz
Frequency response 20-20.000 Hz +/- 1.5 dB
Tracking ability at 315Hz at recommended tracking force *) 80 µm
Compliance, dynamic, lateral 15 µm/mN
Stylus type Nude Shibata on Boron cantilever
Stylus tip radius r/R 6/50 µm
Tracking force range 2.1-2.5 g (21-25 mN)
Tracking force, recommended 2.3 g (23 mN)
Tracking angle 20°
Internal impedance, DC resistance 5 Ohm
Recommended load impedance > 20 Ohm
Cartridge body material ABS/Aluminium
Coil wire material Aucurum
Cartridge colour Black
Cartridge weight 9 g
*) Typical value
I'm Blake.
Need to know the tonearm and its effective mass, including the headshell.
Cartridge Resonance Evaluator at Vinyl Engine is your friend.
http://www.vinylengine.com/cartridge..._evaluator.php
