Hi all-sorry as this has been brought up afew times but have a short list of headshells I'd like to match with the Dl110 with my Techie.
Short history I was going to buy new tonearms but as I use 2 decks to mix on occasion I dumped that idea (was going to be costly) to buy 1 great cart and headshell to use for listening ONLY.
As far as sound goes at home am using Technics1210mk2's with Isonoe feet and boots that have been done with the Timestep external power supplies,Sound hifi open-cell silicone foam mat and as I still mix using the Grado dj200i...
My amp is a NAD C272 2 channel connecting with VAF Dc-X
Now as I said I have been into mixing as my mixer I have the renowned rotary Bozak Cma Dla which has been sent to Justin at Isonoe who has completely upgraded it
and has an external power supply fitted...
So here's my list as I read that heavier is best matching with Dl 110:
What have you matched with the dl's ? And anyone have feedback or opinions on these? What would you pick?
Sumiko HS 12 -13g
Jelco HS 25 -14g
Ortofon LH 9000 16.8g
Audio Technika LH-18/OCC 18g
Oyaide HS-CF 12g
or Isokinetic?
thanks to all you helpers ..
ps also if I was to upgrade my Technics headshells to something else to use with my Grados would that make much difference and any recommendations on which headshells?
what weight headshell will match these specs?
Grado DJ200i Phono Cartridge Specifications
- Type: Moving magnet
- Output voltage: 4mV
- Frequency response: 10Hz - 50kHz
- Load impedance: 47k ohms
- Channel separation: 30dB
- Stylus type: Diamond
- Stylus replacement: User replaceable
- Compliance: 20mm/N
- Tracking force: 2.5 g
- Recommended tracking force: 3.0 g
- Weight: 5.5 g
