Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 86
Thread: A Power Amp for Paul
    I'm Paul.
    Quote Originally Posted by Radford Revival View Post
    I thought it was the bribery
    ....that as well!
    Fantastic chaps, really interesting thread.
    Source: Heavily modified DDDAC using MacBook Pro.
    Amplification: Pre amp-Stereo Coffee pre amp on steroids.
    Power amp- Rather large Colin Wonfor Class A power Amp
    Speakers: Lampizator P17 Open Baffles
    Accessories: Klotz 500 DIY Interconnects & DIY speaker cable sounding better than anything commercial.
    All powered from a Mother Trucker BPS with a dedicated consumer unit with 10mm armoured radial back to the house tails after the meter.
    I'm Will.
    Not the best pic, but if you look carefully you'll see that the mains transformer is not actually flush against the chassis, but sitting about 2mm above it. This is because I use a form of resilient mounting to reduce mechanical buzz. It is difficult to see but in the darker portions of the image you can see the transformer is sat on rubber washers.
    From the underside you can see there are also rubber washers, with large M5 penny washers to spread the load over the entirety of the rubber. The whole transformer is then "floating".
    Here is the hardware I use to mount the mains transformer. I make the rubber washers myself with a CNC router.
    Radford Revival
    www.radfordrevival.co.uk
    I'm Will.
    Here are a couple of the boards that form part of the power supply.
    The HT winding resistance of the mains transformer is very low. This causes pretty sharp charging pulses that cause some of the mechanical buzz. These resistors counteract that somewhat, as well as lowering the HT voltage a little bit. Better to have the heat generated outside of the transformer rather than inside it via a resistive winding. The HT winding is also fuse protected in the event of a catastrophic failure of a capacitor or rectifier diode.
    This board forms part of our new protection circuitry. The control part is on another board, this just houses a relay (440Vac rated), and an HT fuse for one channel.
    We have a big stock of stainless hardware (ignore the errant galvanized hex spacers in there, they are never used!). This is one of a few racks filled with lots various high quality fasteners.
    Radford Revival
    I'm Paul.
    If it wasn't for the green fuse board in the second from last picture Will, I'd say that was just nuts!
    I'm Will.
    Quote Originally Posted by Reffc View Post
    Radford Revival
    I'm Ian.
    Words from another Will......William Morris......Have nothing in your houses that you do not know to be useful or believe to be beautiful.
    It truly is wonderful to see something built with such skill, knowledge and care. I believe you hit the Mr. Morris quote on both counts Will ! This will be a joy to own.
    The HT winding resistance of the mains transformer is very low.........Better to have the heat generated outside of the transformer rather than inside it via a resistive winding.
    What I absolutely admire about your builds Will is the technical attention to detail. Above is an excellent approach and so impressive is to slot the pcb to ensure maximum cooling of the resistors
    Indeed, a very classy build.
    I think your going to love the Radford Paul, they certainly make my MG 15" in your custom cabs sing
    PRE
