Any one have any thoughts/experience of the new Bantam One Amplifier? I was thinking of trying a pair of Temple Audio mono blocks and then the new Bantam One Amplifier caught my eye..
http://www.bantamone.com/index.php
Afternoon
I had the same thoughts a few months ago when I started to think about a change of amplifier and had always hankered after some monoblocks - can't explain why just did
Anyway I found the Bantam One and after reading the review listed on the site I decided to go for it and ordered a Bantam One with a walnut front, walnut volume knob and gold trim - didn't bother with the remote control.
Turned up about a week later and I have been very pleased with the unit - it's compact but sounds really good in my system - plenty of punch and bass (which I like) and dead easy to use.
You deal directly with the guys at Temple audio (John Clayton) who has responded quickly to the couple of questions I had. And they offer a 60 day trial period so you could return if it doesn't gel with your system.
Dave
Currently listening to:
Wilmslow Audio Gemini speakers with external crossovers | DCB1 -> Neurochrome 86 Monos | Matrix Audio X-SPDIF 2 -> Denafrips Pontus II | Roon Server/ HQPlayer | Spotfire interconnects / speaker cable
Thanks Dave, more food for thought Currently using a Amptasic mini-1, but looking for a bit more grunt.
Never heard an Amptastic but I reckon you won't be short of grunt with the Bantam One
Dave
I'm tony.
Havent heard the Bantum one but own an original bantum and four mono blocks. Great amps and a great company to deal with.
My son uses mono blocks with a TVC promethoius, a lovely combo with plenty of grunt and control.
I have a couple of amptastic mini t, they are excellent but the monos are quite a upgrade sonically.
The Monos are great at driving statics (57s/63s) they worked really well with Spendor SP1s and my Electric beach Frugels.
Im sure John on THE AUDIO STANDARD uses a Bantum 1 and rates it highly.
Hope that helps....
Thanks Tony.
The Bantam One is a great amp. It improves on the monoblocks, that's a lot to do with the power supply which IIRC I talked about in the review.
Cheers Clive, great review.
Well, I took the plunge and ordered one a couple of weeks back, it arrived this week. Overall I am very impressed with it, sound quality is great and I love the improved stereo image I am getting. The only downside is I can't use my headphone amp with it, I was hoping I could use the pre-out's but there's no way to mute the speakers, at least there is headphone output on my PiDac and I could alway's use my Tisbury pre on one of the Bantam inputs.
Sounds like a nice product. I've never had my mits on one, but the review is very promising.
