Tape is not cheap either so as Ali said make sure you get the right type first.
These are 2 good suppliers
http://www.tapecity.co.uk/acatalog/O...FUtsGwod1IcPTQ
https://www.thomann.de/gb/recording_tape.html
Besides ATR & RTM there is no other new tape you can buy, RMG was sold to RTM in 2015 so that is all NOS.
The old teacs work very well with Maxell XLI but you can only buty that second hand from the likes of ebay which is where I got most of mine from and it has been very good tape.
From what is available new the RTM or RMG LPR35 would be the best bet
If it didnt come with the player you will also need 2 Nab Adapters for 10.5" spools https://www.thomann.de/gb/tascam_nabadapter.htm
Alan
