First thing I'd check Craig is for networking gremlins.
Easy solution: switch everything off at the plug, including your router/hub..whatever.
(Don't switch your amps off )
Switch back on in this order:
* Router/Hub
...then leave it a few minutes before switching everything else on.
then
* External drive
* SB touch
See what happens after that.
Assuming all things equal...90% of squeezebox issues can be solved by a network reset like I detailed above.
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
