I'm Justin.
The Thorens deck has a long 2-core mains lead fitted which will exit through the plinth base where there is a large cut-out for the motor.
More probematic was the arrangement of the signal interconnects for the SME M2-12R. On that arm, as with all later 3000 series derivatives, horizontally-mounted phono sockets are used. Any horizontally fitted phono plugs will thus clash with the thick solid plinth, so to get around that I had to buy a special lead fitted with right-angle phono plugs at the arm end.
