Results 11 to 20 of 29
Thread: Klotz Mc5000 sonics
    I don't think the plugs make much difference to the sonics (they don't here, put it this way) and it's difficult to do a direct comparison with two different lengths* let alone re-wiring the same cable I think, but the MS ones do definitely 'feel' and 'look' better, so they must sound better too, right? I have a couple of cables here which I've tried in different configs and best, less ripe, sonics have been with the two inner conductors carrying the signal hot and return and the outer 'screen' left disconnected. To be fair though, for *me,* connecting the screen at one end made little if any derogatory difference, but it made for a messier connection - I'm still not as neat as Brian
    The 'worst' I heard from MC5000 is having both inner connectors together as 'hot' and using the outer screen as return. I found it messy sounding this way I remember, although if asked to do this 'blind,' I'd probably not be able to reliably tell.
    * One other thing, continued use does *seem* to make the 'sound' more neutral.. I had an equivalent MG HD1500 made up and when both were new, I definitely got a difference in direct comparison, the MG having more 'sheen' to it. As the weeks became months, the two sounded all but identical on the same system. For me obviously, the Klotz 'won out' because I can buy the wire relatively cheaply and make it up myself.
    As Dave says, how these cables are wired, in respect of which end the shield has been connected or not, has a significant impact on their sonic signature. However, to a lesser extent, so do the plugs used.
    In my experience (and I've been using these cables on and off now for nearly 2 years), there is an unmatched and satisfying sonic synergy between the Klotz cable itself and the MS Audio silver plugs, which simply doesn't happen when other plugs are fitted.
    Also.... Try reversing the cables, so that the end that would normally be plugged into the source (where the shield is connected) is facing AWAY from the source. I find that opens up the sound a little and reduces any tendency for bass 'fruitiness'.
    Bigman80 Guest
    Well if Marco is using them with his certainly high end gear, they must be a good match.
    Going to put some on my interconnects at some point.
    I can't claim to have 'heard' a difference with the MS plugs, BUT, they're not silly money and the slick feel in use is very much appreciated here. The fall out from Brexit may push the price up nearer to £20 a quad set and that's sad. I still think the £1.50 or so Neutrik is a damned good plug though and recent ones do look posher than they used to.
    Bigman80 Guest
    Just paid £20 for a set of 4 rhodium MS Audio plugs.
    Nice one, mate. Let us know how you get on
    Bigman80 Guest
    Will do,. I also have a set of pure copper plugs I wanted to try. Need more cable though lol
    Bigman80 Guest
    So I stated I was gonna make up a couple of sets of interconnects with different plugs and do a bit of a test. So here goes with my findings:
    Klotz 5000 with Monster gold-plated plugs
    I've had these running between my DAC and amp for a few weeks and had been very pleased. Bass was deep and treble was crisp and high. Everything seemed to be fine, timing, tone and musically they just fitted right in. Vocally they were pretty much as good as I'd heard from any cable.
    Klotz MC5000 with MS Audio Rhodium
    What the F@ck ! How can RCA plugs make such a difference ? The MSAudio plugs sounded incredible. Everything all of a sudden is crisp, like frost. Bass is definite. Solid and taught. And the treble, oh the treble is excellent. But the biggest difference is detail. It's like I'm hearing more subtle nuances and there are symbol trills I haven't heard before.
    In comparison, the monster plugs sounded like a muddy mess.
    I didnt want to like the MSAudios because that means I have to upgrade all of my plugs but I do. They sound great.
    Buy some.
    Now you need to look at Cardas or Audio Note pure copper cored cable. Then it will all come together.
    Bigman80 Guest
    Stop it Geoff ! I haven't got the budget to keep upgrading !!!
    What are you using ?
Tags for this Thread
