I have a metre length of this interconnect which I simply can't make my mind up about it. I find it over smooth when used with my Firebottle phono stage. Let me know your thoughts.
What plugs are fitted to them Steve . I fit either Rhodium MS Audio , silver MS Audio . and gold plated plugs to these cables . All change the sonic character of the interconnects .
Regards
Brian
Amplifier : Sony TA FB740R
Speakers : Tannoy 637
OK mate I'll have a look at them and get back to you .
Regards
Brian
I use neutrik, snake and monster plugs lol they're different on each set and I just ordered these to try :
Look at this on eBay http://www.ebay.co.uk/itm/161677296429
Sonically I haven't noticed any difference but they all have the same construction material I suppose. I'll let you know if the copper ones make any difference.
Bass can be a bit fruity...which may be exactly what your system needs.
As Brian says the silver plugs counter that somewhat.
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
I would try MS Audio silver plugs on these Steve as they will give you more detail and top end sparkle .
Regards
Brian
The look like gold plated Neutrik connectors to me
I mainly use these cables, they gave me a big bold detailed and spacious sound . Better than much
Of what I had tried before.
Source: Heavily modified DDDAC using MacBook Pro.
Amplification: Pre amp-Stereo Coffee pre amp on steroids.
Power amp- Rather large Colin Wonfor Class A power Amp
Speakers: Lampizator P17 Open Baffles
Accessories: Klotz 500 DIY Interconnects & DIY speaker cable sounding better than anything commercial.
All powered from a Mother Trucker BPS with a dedicated consumer unit with 10mm armoured radial back to the house tails after the meter.
Yes they look very much like Neutrik plugs . They're good enough plugs but the MC5000 cable and the MS Audio plugs are a very nice combination .
Regards
Brian
