Results 11 to 20 of 27
Thread: Teac VRDS-T1 Transport
    I'm Neil.
    I agree. You have one stompin' transport there, Bev.
    I was amazed when I had one. It eventually needed a new laser but they are pretty cheap to buy which surprised me.
    Moving up the chain, I don't think you will really need to bother with the intermediate TEAC transports until maybe the P30 which is a monster but also now quite expensive to keep running regarding lasers unfortunately.
    So, well done... it's a keeper IMO.
    P30 is a great transport.
    I had a P3 Esoteric, but it was a bit mechanically noisy so moved it on, but that comparison between it and the P5 I did was sobering, the P3 ate it for breakfast.
    Regards Neil
    Well I just plugged the Teac in and I cannot get the tray to open....
    I'm just looking around it for any transport screws but can't find any
    I may have purchased a dud.... ooops... If that's the case then I guess it's the only bit of hifi I've purchased that has showed a fault so after all these years I suppose it had to happen at some point..
    Bev
    I'm Josie.
    Ah... inside you will find a cog that will have become misaligned... check that first.
    Tannoyista.com
    - Audio Equipment Reviews
    Facebook
    I'm AMusicFanNotAnAudiophile.
    Is the fuse in the plug ok?
    Chris
    Common sense isn't anymore!
    Thanks Josie I will take a look in it
    Bev
    Yes Chris the unit does power up ok but just won't open
    Bev
    There is a hole in the bottom of the unit
    Can anyone tell me if it's there for a reason, like a transport screw etc, or just a hole ?
    Bev
    I'm Paul.
    There is a single transport 'screw' accessible from underneath, at least that's if it the same as my VRDS10. The clamp mechanism locks the laser sledge from what I remember.
    The other likely problems are a broken drive belt on the opening mechanism or a broken plastic drive cog.
    Good luck with the search.
    Paul
    Worth getting fixed though if thats all thats wrong, and possibly is. Built like tanks
    Quote Originally Posted by Dalek Supreme D L View Post
    Yes, nothing else you have will come close. You will hear exactly why transports matter and make a difference.
    Neil, this is a T1 transport, a sheep in wolf's clothing, in other words a dressed up low cost Sony...
    http://lampizator.eu/LAMPIZATOR/REFE...1/VRDS-T1.html
    Doesn't mean it's bad, but it ain't what the bigger VRDS mechs are...
