Any ideas on these from users?
Hi Grant,
It's not particularly cheap https://www.amazon.co.uk/OPPO-na-Opp.../dp/B00U1PQVWU but my son got one of these from his work.
He works for CEX so got it for about £170 with his discount and he swears by it.
He uses it when he is out and about with his Fiio X3 and says the quality is very very good.
Again it's not cheap so might not be what you're looking for but it does the job handsomely.
Cheers,
Alistair
On the amp front I had a fiio e12a and quite frankly it was rubbish. I preferred the sound of my iPod with all my IEMs including my hard to drive Sony quad armatures. It was rated as a good fiio, I get the impression that some reviewers of portable equipment dont set the bar as high as us "audiophiles". Now a nice cmoy amp with a 9v battery that's different, I love mine. I started with a JDS labs bass boost in an Altoids tin but then came across Zigis who sold a variable bass boost with a knob which I find much better. You can also overdrive it at home with a PSU I think mines 24v. Keep 2 9v batteries charged and you can switch over when out and about if one runs out. SQ is good enough to match an entry level desktop amp.
PM sent Grant
Kraken, Saturn, Emotion, Flying V Rocket, Planets.
I'm Des.
I had a Chord Mojo (only sold as I stopped commuting) and thought it was a step above anything else in the same category. Drove IEMs and big AKGs equally well. Didn't sound too bad in my main setup either, at least the equal of the Rega Apollo I had at the same time.
Rega RP8/RB3000/AT OC9XML, Clones Audio PA1, DDDac1794/Pi4, Rega Elicit-r, Bastanis Wildhorn speakers.
Thanks all. I will start checking these out
Hi Grant, do you want it to be truly portable, i.e. in your pocket, and on the move?
I use an iFi nanoDSD, which is compatible with Android/iOS/Windows via USB (OTG for android), has it's own on board battery, and can be set to power itself, or power/charge from the host device (usually a laptop/PC).
https://www.amazon.co.uk/Headphone-A...words=ifi+nano
I'm very happy with it, works very well with my Sennheiser Momentum IIs
That said you wouldn't want to carry it in your pocket... It's more to use at a destination, than on the journey, although I do use it on planes and trains...
Another advantage is that it has stereo RCAs out, in addition to the HP socket
Cheers, Will
yes, pocket size but if it can be utilized on desktop or main system if needed its a bonus. Just found my sony buds. sound pretty decent with the phone streaming Amazon actually. got a set of sony bluetooth ones too that were state of the art in the day(quite a while ago admittedly). got them on charge at moment. Either dac/ amp or maybe just amp may be enough. Its for my enforced bed times lol. Actually thinking of keeping amazon system for a few months, while I trial all the others, but its the cheapest and has no ads etc, plus it has all the music I ever bought from them which is quite a few tracks... about 4000 I think.
The nano and the oppo look very nice, but out of budget i think at moment. Have another option via a trial of of an amp from Dave(Jollyfix) which I may well try now ive found the buds. Had a decent set of sony over ear ones too but they seem to have varnished
...at the other end of the scale, amp only, the little FiiO ones are pretty good...
https://www.amazon.co.uk/FiiO-Portab...ywords=fiio+e6
...I have its predecessor the E6
Cheers, Will
A Graham Slee Bitzie - https://www.amazon.co.uk/GSP-Audio-B.../dp/B00SU4ND8Y
If you join the forum, and post there you can get 10% off.
Kevin
