You got anything in between the slabs?
Blue-tak works well to "couple" the slabs together and add mass...
Can deaded the sound though, so maybe something squishy between them (to isolate) might work out better - system dependant of course.
Watch what your doing though....its to easy to get Mana-ised with this stuff!
Gonna nip down to Tescos today and pick a couple up - fit under the dac very nice.
I've just the squishy feet sittingunder the Dac casework - shold improve things even better.
My SB3 sits on the Dac same as yours GetGaf...top tip mate, thanks!
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
