I'm a firm foo mains cable believer and have been for years.
I'm a fan of Nordost Blue Heaven (previously branded as Magus).
... although there is a new type in the post to me atm. I'm quite excited!
I'm gone.
I'm Stephen.
Nordost recommend upgrading mains cables first before interconnects and speaker cable. Mains is the foundation of the system. When your really into it you also change mains plug fuses or go over to Euro Schuko connectors. The icing on the cake is when you replace component internal fuses with Synergistic Black.
All my cables have Schuko plugs but then I live in France. No fuses of any kind, no matter how exotic and expensive, just the circuit breakers at the consumer unit. If we do move back to the UK (or Scotland if it's independent by then) I'll keep the Schukos. If no fuses aren't better than special ones, then summat ain't right
Internal fuses... I try and hide my slightly lopsided grin
I'm gone.
I'm Stephen.
Its absolutely fine if you want to run your system with kettle mains leads and budget interconnects, example here;-
https://www.amazon.co.uk/1m-TWIN-RCA...ect+cable+hifi
All I am saying is you will not get to experience your systems true potential.
Kettle leads are fine.
I'm Allen.
I've tried probably four mains cables over the years, all in the under £150 range. For half of them I heard no difference. For the other half, the sound got a bit aggressive and lost nuance, so I've always returned them. But I just tried some Furutech FP-TCS21 (DIY) on a lark, and was very pleasantly surprised. Good improvement in space & dimensionality, with bass deepening whilst maintaining control and texture. I'm really liking the improvement in my sound. But they took many hours to burn in before they sounded this way.
Bruce
Theories are not so much answers as questions, to be supported or undermined by experience & testing.
Source: Audiolab 6000CDT > Calyx 24/192 DAC
Amplification: Pass-design B1rev2 pre-amplifier > Neurochrome Modulus 686.
Loudspeakers: Proac Response 1SC
Cables/stands: spkr: MIT MH-750 biwire; IC: HT Truthlink; Target stands, sand-filled; Excel Cat6A 23AWG UFTP & 1attack.de Cat.7 SFTP.
Other: Balanced AC transformer to hydra mains distr; Bass traps & Acoustic panels; Isolation: Inner tube & roller bearings; 3xZyxel ES104A switches in series w/Vreg upgrades.
Cables don't burn in.
I use a Mark Grant mains cable like this one:
https://markgrant.co.uk/mains-power/...er-plated.html
I use that for the amp but the rest of the system uses standard stuff until I get round to replacing them with the above cable... I love Mark Grant cables of all kinds...
Bev
