Results 1 to 10 of 11
Thread: Wanted. Intermidiate glass shelf for a Stands Unique unit.
    I'm Paul.
    Default Wanted. Intermidiate glass shelf for a Stands Unique unit.
    On the look out for a spare intermediate glass shelf for a Stands Unique unit, Glass size 0.48 deep by 0.60 wide and four support pegs if possible.
    Thanks
    Is that the 6mm or 10mm version? I've got plenty of 6mm.
    I'm Paul.
    Hello Geoff,
    They are the 10mm ones.
    Thanks
    Quote Originally Posted by Geoff101 View Post
    I'm Peter.
    Default Stands Unique 6mm shelves
    Hi Geoff,
    do you still have some 6mm shelves for Stands Unique Towers, the dimensions I need are 550mm x 330mm
    all the best
    Peter
    Movies ~ oppo 105 ~ marantz SR8001 ~ tannoy precision ~ BK Monolith Sub
    Vinyl ~ beogram 8002 ~ graham slee accession phono pre
    Red Book ~ Teac PD-H600 ~ red wine audio signature 30.2 ~ akg k-1000 headphones
    Quote Originally Posted by p147 View Post
    Thanks
    Paul, if you go to a local glass merchants, they will be able to provide what you need. !0mm glass isn't cheap, and of course it would need to be supplied toughened, and the edges polished/bevelled. Probably cost about £40 to £50.
    Quote Originally Posted by pcourtney View Post
    Hi Geoff,
    all the best
    Peter
    Yes, I'll check the dimensions tonight.
    I've got at least 5 of that size.
    I'm Peter.
    you have pm Sir
    @Geoff101 Hallo Geoff, I know this is 2 years on but do you happen to have a bottom shelf 535 x 420 and an internal shelf plus whatever is needed to add it to the Midi Tower? Thanks, Mike
    Hello - yes, I've got at least a complete rack spare.
    Posting it might be a bit dodgy though. Do you come up past Oxford ever?
