WTD Help advice Wadia 381 Cd player
Does anybody know how to set the outputs on the XLR'S/RCA via the players internal dip switches on a Wadia 381 CD player? The manual says they can be set for Default 2 mV or can be set to 4/8 mV internally but is a dealer fix. I would like to buy one but would need to reset to higher volts for my system. I do know that it can be used as a Pre amp but the same still applies if using the inbuilt volume control.
Regards Robert.
- You may not post replies
- You may not edit your posts
Forum Rules
