http://www.musicdirect.com/product/74632
Mr Coco got one from Japan - Says it works very well.
Anyone else tried one?
Hi Steve,
Yep, I've got one of those and it works pretty well. It's especially good at removing larger 'blobs' of built-up gunk after, say, playing some older LPs that I haven't yet put through the RCM.
However, I much prefer this which I recently won on Ebay:
http://theartofsound.net/forum/showthread.php?t=4723 It's just a pity that they don't make the buggers anymore!
I also have a Zerostat pistol, which is great for neutralising static. I give records I've recently cleaned on the RCM a quick 'zap' before popping them inside a Nagaoka anti-static sleeve
The work we put up with, eh, for our love of vinyl!
I'm ChrisB.
Steve,
Please, please, please, save yourself some cash & listen carefully to what I say:
You need some sticky hands.
In this thread
http://theartofsound.net/forum/showthread.php?t=551
I wrote in Post No. 5
Heres what they look like:As for the Sticky Hands:
Works the same way as the £30 Zerodust - but I got 24 of them for under a fiver! You have to keep it in an airtight container or it will dry out. Works really well. Once again you dip the stylus in with the lift/lower mech.
http://cgi.ebay.co.uk/Bulk-Lot-Stick...item5d26b4a1d8
This seller is in Australia, but I only put this link in because it has a good picture of them. Do a search & find the best deal, taking postage into account. Mine came from the US & the price was under a fiver for 24 including shipping - I've had my fivers worth many times over. In the years since I bought them - I'm still only on my third one & I've given loads away.
They are functionally identical to the thing you are thinking of spending $60 on.
Good call, Chris!
I didn't pay $60 for mine though. I bought one from Kevin ('bong') for considerably less when he was in holiday in Hong Kong and brought some back with him
I'm ChrisB.
I hate to see folks spending cash unecessarily!
Of course it doesn't come in a flash box like the Zerodust, but when it gets grubby or loses it's stickiness you can chuck it away & use another.
............plus the fact that you can't use the Zerodust for snatching stuff off tables at a distance of 3 feet!
I've got one but I don't think it's as effective as the dense brush type like the one Marco blew two week's wages on, with or without vibrator.
I'm ChrisB.
Well, I think they have a slightly different balance of advantages & therefore suit the removal of different types of residue.
I have/had a Stanton (or was it pickering) cleaning kit with a wooden handled plush type brush (used dry) and a retractable close bristle brush for the stylus. I don't know where it is now, but the AT cleaning fluid and "carbon-fibre" brush does very well for me.
Marco, you don't need to use the Zero-Stat before putting LP's in the nagaoka sleeves, as these sleeves do a fantastic job all on their own...
