Results 1 to 6 of 6
Thread: TC-7510 mk6 advice
    I'm gerald.
    Default TC-7510 mk6 advice
    I have just picked up a TC-7510 mk6 and little pinkie power supply I know the volume button on the front controls sound level output but what position should it be for set for my amp also the what is the average cost of the mod21 labour wise and who can I send it to be done ?
    Cheers Gerry
    I'm gerald.
    Anyone please
    Maybe drop Stan beresford a pm. he should be best able to help with all your queeries there.
    I'm Will.
    Quote Originally Posted by diviy View Post
    Cheers Gerry
    What sort of amp are you running it into, power, integrated, pre ?
    On the back of the DAC there are 2 sets of outputs, one to use it as DAC only, the others to use it as DAC and Pre?
    Cheers, Will
    I'm gerald.
    It is going to a Arcam A65 running as a pre but waiting on a valve pre coming
    I'm Will.
    So you should be running from the line level out, and therefore bypassing the volume knob...so wherever looks prettiest
    Cheers, Will
