It's not a million miles away from the ECC83 in characteristics and has the same pin-out. So yes you can use it but as I keep saying about "tube rolling" you can't expect a valve other than the one the circuit was designed for to work as well as the original.... or as well as the new valve should if the circuitry was redesigned to accommodate it! And that's if the pin-out is compatible (yes in this case).
Most of the time you will be hearing what it sounds like with the wrong voltages and wrong resistances.... and hence likely that THD has gone from say 0.1% with the correct valve to 5% cos the wrong one's now in!! It is infinitely more important that the correct type of valve is used than anything to do with what make it is or anything else!!
As it's a cathode follower in this case though you should pretty much get away with it...
