Thanks Grant - there's nowt on ebay along those lines at the moment.
I'm gone.
Think I have one somewhere, a rolls headphone tap. sure its kicking about, but not sure where. there is an ART one too which should be same
https://www.studiospares.com/Headpho...nOtBoCi6Lw_wcB
There's a vintage one on eBay: http://www.ebay.co.uk/itm/1723615763...%3AMEBIDX%3AIT
If your phones have the now normal 3.5mm plug you'd likely need a standard jack to 3.5mm adaptor as well (dirt cheap).
Careful with these adaptors though.... what you want is a direct connection to your speaker outputs. Many of these adaptors have internal resistors and/or vol control and therefore you would be back where you started with the stock headphone output on an amp (which usually have attenuator resistors fitted).
I'm gone.
If you win the cans give me a PM
I'm gone.
OK, thanks Jez.
I'll ponder my options - the seller turned down my first 'generous' offer.
I don't need the things, in fact they are the wrong design for me in crucial ways.
They are intriguing, though!
