You might well find a regenerator of use. Ive found it to make a huge difference in my system. Can be had at modest sums comparatively to price of some things.. they can come expensive too. I bought mine second hand and is a power inspired
Re power cables: buy a used one cheap and see if you can tell any difference with that before you spend any serious money in that regard.
hi
for a dac,i can highly recommend one of these
http://www.ebay.co.uk/itm/TEAC-UD501...sAAOxy86RSYW48
had one for about 3weeks now ,brought from this seller....very quick trouble free delv.....and one hell of a good dac,and ive heard plenty.
have no vested interest in the seller or connection....just a good experience from buying through them
regards
smithie
it could seem quite pricey i guess
but it has some decent useful features that i like and is good for a hub for all my various digital bits and pieces,its also quite future proof as far as these things can be,plus it has filters that you can actually hear make a difference,very well built to,as for sound...love it....worth getting dual mono dacs for the seperation and soundstage magic it brings to the party
regards
smithie
I'm Deividas.
Thanks for advising guys.
Sent from my GT-I9300 using Tapatalk
I'm Deividas.
I was looking in the range off 1k for second hand. or 2k for new
