I'm Allen.
That's strange Al. I've owned Techies and not had hum issues, even using Deccas and Grados, which can be sensitive to hum.
I'm Nathan.
The Technics power supply transformer has a slight hum that can be heard. Just mute the volume when playing a record without lifting the tonearm. Once the record stops spinning, turn the volume up gradually and you should be able to hear the transformer hum. With an outboard PS you won't hear this hum. With music playing, the absence of this manifests itself with a quieter background and more low level detail previously obscured by the stock onboard mounted PS. I did the DIY external PS mod on my deck and noticed a benefit from it. From what I've gathered, an aftermarket PS has better power supply and regulation in addition to getting rid of the hum. For now I'll keep using my DIY solution as long as I don't get the "bug" by hearing a better one
We the willing, working for the unknowing, are doing the impossible for the ungrateful.
We have done so much for so long with so little, we are now qualified to do anything with nothing.
I'm Deleted.
There's no magic or questionable 'snake oil' to turntable power supplies - the improvements brought to speed stability and motor vibration are easily heard and measured. In the case of the Technics things are a bit less clear cut as the turntable already contains a power supply and feedback circuit. Moving the transformer outboard should be worth it though.
Account Deleted
I'm Nathan.
I'm Nathan.
I'm Packgrog.
FWIW, I've been doing an experiment trying to get the Technics to sound as good as my Michell TecnoDec. Several hundred dollars into the experiment, and money has dried up, while also not yet succeeding. Audio samples can be found here: http://audiokarma.org/forums/index.p...2#post-9991512
Analog: VPI Scout Jr. | Phoenix Engineering Falcon PSU | DIY tach | Funk Firm Achromat | Michell Clamp | AT33PTG/II | Musical Surroundings Nova Phonomena | T.C. Electronic Desktop Konnekt 6 | Sonix IV ST136H Ultrasonic Cleaner | Okki Nokki Record Cleaning Machine
Digital: iBasso D14
Headphones: Lawton-modded Denon AH-D2000
