i have got hold of a Beresford TC-7510 DAC but it does not have a usb input what is the best way to connect them up?
Gerry
I'm gerald.
Gerry
What laptop do you have? It might have an optical output, which you can use.
If not, you will need a USB to SPDIF converter.
I'm andrew.
As above
You will need a usb to spdif converter something cheap and cheerful should do, I think Behringer do one for around £25 or you could look out for a used M2Tech Hiface which should be better or Beresfords own http://www.homehifi.co.uk/PP/cartview.html?id=27
Andy.
Website: http://www.homehifi.co.uk
Website: http://www.beresford.me
Website: http://www.homehifi.asia
Source: Heavily modified DDDAC using MacBook Pro.
Amplification: Pre amp-Stereo Coffee pre amp on steroids.
Power amp- Rather large Colin Wonfor Class A power Amp
Speakers: Lampizator P17 Open Baffles
Accessories: Klotz 500 DIY Interconnects & DIY speaker cable sounding better than anything commercial.
All powered from a Mother Trucker BPS with a dedicated consumer unit with 10mm armoured radial back to the house tails after the meter.
There's quite an interesting article here - http://www.computeraudiophile.com/f6...hootout-15327/ if you fancy a longish read.
Problem is that some of the kit mentioned is quite expensive, and it could be cheaper to buy a new laptop with an appropriate output - such as a Macbook Pro - or pick up a used one, or a Mac Mini on eBay.
Dave
I'm gone.
Are you sorted now, Gerry?
If not I've a spare USB converter you can have.
One of these - cheap but surprisingly decent! http://www.ebay.co.uk/itm/1318882803...%3AMEBIDX%3AIT
I'm gone.
Hi Gerry
Your inbox is full!
here's how to use the USB converter I just sent you ...
Plug in the USB cable.
Right next to that USB input socket there are RCA and TOSLINK output sockets. Use whichever you want to connect to your DAC.
