should I buy "PI+good dac" or using Network streamer, Normally I listen music online from tidal or dezzer.
Can you recoomend some? or where I can find a good review about them.
thanks
Nop
I'm Nop.
thanks
Nop
I would think the chromecast audio disc streamer is your friend here. Think it only does redbook but works with deezer premium etc, either from pc or a tablet/ phone...ios or android. Its cheap and very good. Works well with tunein radio too and plenty more including foobar2000 via a pc and android.
I'm Nop.
thank you Grant, I will quickly go to take a look in chromecast !!! All specifications that you list are all I want.
regards,
Nop
You may have to check locations from where it works as cannot say about Thailand
Chromecast access is thru one's phone screen.. ewww.
Roku comes with a Remote and 'claimed' Much higher source availability.
