As Spendorman says generally.
The later ones had some changes such as different output transformer spec which were designed to cut the stress on the EL84's and prevent any risk of thermal runaway in them...
Earlier type probably better sound quality as higher HT used and greater amount of screen grid feedback. early ones likely to be harder on the output valves and will need decent ones fitted for them to work for longer than a few minutes in the worst cases...
I recommend Russian 6p14EB (exact name will very depending on translation of the cyrillic) as a good sturdy replacement for EL84s.
