Hi all, I hope this is the right place to ask this. I bought a secondhand DIY Camp Amp #1 a while ago and recently tried using linear power supplies with it. I'm getting some odd results though and would like to run this past those of you who actually know what you're doing with electronics ('cos I sure don't). This is just plugging stuff in, no actual DIY.
1. Running with the original (19v 4.7A) SMPS supplies the amp sounds great and I have no issues.
2. When I plug both linear supplies in (Maplin test bench supplies with front meters) turning up the voltage on one also turns up the voltage on the other. If I reverse the wires on both the same thing happens. If I alternate so red to black on one and red to red on the other the ammeter hits the end stop hard and is presumably a short (yes, I actually tried that...)
3. If I just have one PSU switched on or plugged in then both channels play normally. The same is true when using the SMPS.
4. If I run the LPSU at 12v the power consumption is about 200mA and everything works. If I turn the voltage up towards 19v the ammeter start to run away ahead of me and hits the end stop (3A). I switch it off at that point so don't know what happens next.
5. Using one or both SMPS the power consumption according to my AC regenerator doesn't change: it's pretty consistently 57 watts above that for my sources, with a little more after first switch on.
6. My first experiment with the LPSU had connectors with metal ends. I've now switched to connectors with plastic ends but I get the same results.
My questions:
Is it safe to have two PSU plugged in and switched on at the same time. It's obviously worked fine for at least three owners using the SMPS, so I'm asking theoretically. I
think the amp sounds a little weaker with one, but I may be imagining it.
Is it safe to run the amp at 12v, or will that damage anything?
How many amps should the amp be fed at 19v if running from one supply? I have a 19v LPSU that can put out 5 or 6 amps I believe, but I'm not willing to try it unless that should be fine (it cost more than the Maplin supplies).
Any comments or abuse welcome.
I don't expect a warranty with a DIY amp so I'm not bothered (and being able to run it off one PSU is actually a bonus), I just want to make sure it's electrically safe.
