I've just received my Zu back from repair at Zu in Utah and was setting it up again and thought I'd try and get it right this time by using a calculator to work out the correct mass that the cartridge should have in relation to my Mission 774 arm.
Standard figures are:
Cartridge weight 14g
Arm effective mass 5.5g
Cartridge Compliance is 5 cu (5 x 10 –6 cm / dyne)
Now I've bodged up extra weight on the cartridge AND the counterweight and it sounds pretty good, so it must be right, right
I used a figure I worked out using a formula I found on the net, but I'm wondering if someone can tell me what THEY think the weight of the cartridge should be to get the figure to fall within the 8-12hz range that's supposed to be ideal.
I'll then know if my calculation is correct lol.
I'm not telling you what I have it at in case I'm found to be a complete numpty
PS: Photos to follow once I'm proven wrong lol
