Here's a nice little project. A turned aluminium arm base. As per the original it has the Linn three hole fitting and 2, 120 deg opposed grub screws to securely hold the arm pillar.
are you sure that measurements right? ive just measured my alphason pillar and the size is 18.48 mm?
My System
John Wood KT88 Amp.
Paradise Phono Stage
Sony TTS-8000 Turntable.
PMAT-1010 MK6 Tonearm.
Ortofon Cadenza Bronze
Sony X555ES Cd Player
Yamaha NS1000m Speakers
The measurement was to Rexton's spec. He's just contacted me to say its 18.5mm.
I will bore it out to the new spec.
Thanks for letting us know.
Now that's service for you. I cough up later!
Glad it was spotted before posting
My System
John Wood KT88 Amp.
