One set of speakers purchased £60.00 one owner from new
I'm gerald.
i have a spare set of crossovers for these,i bought them when i recapped mine in case i wanted to return them to original spec
My System
John Wood KT88 Amp.
Paradise Phono Stage
Sony TTS-8000 Turntable.
PMAT-1010 MK6 Tonearm.
Ortofon Cadenza Bronze
Sony X555ES Cd Player
Yamaha NS1000m Speakers
I'm gerald.
Jamie do you have the specs of the cross overs you built by any chance please
yep,im looking at one now,its 4.7 low loss elcap fitted as standard.
here's a link to buy new,
http://www.falconacoustics.co.uk/alc...le-series.html
My System
John Wood KT88 Amp.
I'm gerald.
How many cap do i need to get ?
Next question my kef 35 seem easier to drive they both 8 ohm but to get a half tidy volume i need to crank the volume up way more than i did with my q35 and I am not playing them at my normal volume just running them in as they been standing for a few years any ideas ?
1 cap per speaker.
My System
John Wood KT88 Amp.
Have you checked to see if all the drivers are working correctly.... That both Tweeters and mid/bass are producing sound?
Easy to miss a blown driver when you first get them
I'm gerald.
All driver work opened them up tonight cap is the original speaker contacts are corroded and all the driver gaskets are rock solid plus point all the foam is perfect time to order some bits tomorrow
If you want gaskets, use either stick on foam strip or foam craft sheet and cut them out. Both items can be found on eBay and are avilable in black. Craft sheet can also be bought from art and craft shops.
