mmm, sounds like you're not far off sorting it
I'm Phil.
Player bit shows music on left pane but the right hand side isnt working as it says no player, so the ccast is not getting picked up there. Maybe this whole thing would have been easier if i had a sqeezebox. Or a younger brain. Cant get over this .tried it several times and im getting no further
In comparison the foobar version is click n play. Not sure why this isnt lol
I'm Phil.
Sounds frustrating , maybe have another go tomorrow
Meantime I will just use the foobar as it works. If and when I r someone has a bright idea, I will give it a bash..thanks for help anyways.
I'm Paul.
There is a thread on the squeezebox forum that walks you through it. Try turning the CC off and on.
In LMS it should appear as a player in the top right.
In the walk through it explains the configuration file. Bit of a faff but once sorted it's easy.
SBT/Chromecast/TEAC T1 into TEAC D-T1 DAC or olde-worlde Rega Planar 2 controlled by Rotel RC850 into HH S500D or DACT Passive Pre into Mullard 5-20 monos. Then into Tannoy Cheviots and a Wharfdale sub. All connected by colourful cables.
I'm Paul.
Announce: CastBridge = integrate Chromecast players with LMS (squeeze2cast)
https://r.tapatalk.com/shareLink?url...3&share_type=t
