It was ..at least i think.. Got it at sourceforge. Un packed it and put it into the program... Restarted efc but it kept unticking and saying failed to load i think. Got fed up lol
I'm Phil.
All I did was load up the LMS web control, go to settings (bottom right), this opens new tab, then go to plugin tab, scroll down to 'other 3rd party plugins', then enable the Chromecast bridge, hit apply, then I think it says you have to restart, the plugin will then appear top right, choose player, little drop down icon.
Have a bash with that Grant
Dont think i got anything like that... Need to try it again. You go a url for everything you downloaded perchance?
Got it installed this time but have no player and nothing in top right
I'm Phil.
Hi Grant, has your music loaded into it? (was automatic on mine I think, took a little while)
I'm Phil.
Further thought, have you got an icon on your task bar? If so, right click it and choose 'open web control', then you get your player up, ready to use
Seems to be.. Found the cast thing and installed it.its not wirking though
Under advanced you get the bridge with lots of options. Doesnt say what to do though.
Also says with unticked box squeeze2 cast
Also in red further down it says parameters empty etc
I'm Phil.
Hi Grant, it's all done through the plugin tab, is the cast one now in your 'active plugins' list?
Seems to have found chromecast as its ticked in settings advanced area but in web player it says no player... Crazy system
It chows the ccast at bottom of page yes, but in the play bit it is not found. Also tried a remote with a android but it doesnt work..
Ah well, worth a try. Seems more complicated than others tbh.
