I'm Mark.
If you have just the boards (I would prefer it if you could source the hard to get XR2206 IC as well. You could ask Rexton (Andy) where he got his maybe? I may have one if I look hard but not sure) and I supply everything else, we are talking £600 ish depending on chosen casework. That price is including a case at around £80...
I'm scott.
other way is to use a VFD variable speed drive / Inverter
Garrard is 19watts to small be be classed as a fractional horsepower motor
VFD used in industry for decades to control motors & they go up to 100,000+ HP
micro drive 0.37kw ( 370watts ) are less than £100 & made by the million by the likes of ABB
Chip IC Drives could also be used
nb - if i doubt consult a professional electricity is dangerous
http://www.tnt-audio.com/accessories...ter_420_e.html
http://www.abb.com/productguide/prod...e8&db=seitp322
I'm Mark.
Jez Thanks for you're reply, I have two of Nigel's boards but have not got the IC.
However I am not sure this the ideal controller for the Garrard. Ideally I would like a controller which can adjust voltage and frequency but this does not seem to be available at present.
The Nigel's DOES adjust both frequency and voltage! I've had a look for the XR2206 but it seems I must have used it at some time...
There are plenty of alternatives to the XR2206, some of which are likely to be better than the XR2206... which makes it strange that this device was chosen... I wonder if it was designed several years ago when it was still readily available? Unfortunately none of these are compatible with the Nigel's PCB.
I can also offer a speed controller of my own design with slight improvements over the Nigel's but it would be a bit more expensive.
Having now doe a bit of googling it seems the alternatives to the XR2206 are all also obsolete.... No problem though as I can build an even better discrete sinewave generator....
I'm Mark.
Hi Jez,
What did you have in mind and how much would it cost?
The boards I have are marked "Turntable motor speed controller" Version: 1.3 NS 05/13. I am not sure if this is the current board that Nigel supplies but I am not aware of any changes to the layout.
Thanks
Mark
That's exactly the finished board I have here in front of me (for Andy, Rexton. STILL waiting for delivery of casework from China...). It should be not too difficult to obtain the obsolete XR2206 IC as they were made and used in large numbers for about 20 years. You will have to obtain it yourself though as there is no point in you paying me to trawl websites and ring suppliers when this is not a technical issue.... As I said in an earlier post it may be an idea to ask Andy where he got his from. I've heard that there can be the common problem these days of fake IC's so be careful...
The improved discrete version would be something I would use in an all Arkless Electronics speed controller which would be rather more than the Nigel's, mainly because I would not expect to sell more than 4-6 and so I need to recoup R&D costs from only a few sales... I would make it a bit better than the Nigel's in terms of waveform purity but I couldn't say if the sound would be any better, so for the budget concious, the Nigel's is certainly the way to go. This would be, as I mentioned in an earlier post, about £600 all in, exact price being variable according to what casework you choose etc (about £90 for empty case alone in this example... yes folks parts can be a small fortune when not buying 10,000 at a time!)
I guess many are waiting for a solution at say £200 but it costs more than that for just the parts when making one off's! It is, like many such things, rather a catch 22... if they were being made 10.000 at a time the cost of the parts would go down by around 75%... but there is nowhere near the demand to justify making them as anything but one off's, to order....
I'm Paul.
Nigel has a stock of tested NOS XR2206s available, in fact I've just bought a couple, find him in the traders section on Lenco Heaven. Only £4 plus postage.
Paul
