Results 1 to 10 of 13
Thread: RPI IQAudio DAC+ Re-Sampling
    I'm Josie.
    Default RPI IQAudio DAC+ Re-Sampling
    Hi all.
    Just wondering. Does anyone use 32Bit 384khz re-sampling with their pi/iqaudio dac+ ?
    I've been looking around and it seems that there is a mismatch to what it can 'actually' do. That is it can resample up to 32Bit 384khz but it outputs 24Bit 192khz?
    I've just been looking at the audio info regarding this whilst playing a track it seems to be correct. So, why is the higher options available to choose from? What's the point in re-sampling higher to then output lower?
    Also, has anyone found that using the Pi3 to be any better whilst using re-sampling or do we generally set it the resampling to disabled or 16Bit 44.4khz?
    Any more info would be great.
    Thanks.
    PS... Does anyone find that the DSP Programming options beneficial with certain rates?
    Tannoyista.com
    - Audio Equipment Reviews
    Facebook
    Ive been using that setting Josie. I,m using an audiophonics board.
    I'm Josie.
    Ah.. thanks, Grant. Interesting.
    Could you check with your Audio information in Moode and paste it in? I'd like to see what it says in regards to output.
    Thanks
    Tannoyista.com
    Facebook
    I'm Josie.
    Ah... ok. I missed this in the info panel.
    Architecture: Sigma/Delta Advanced Segment 24 bit 192 kHz
    Makes sense in one way now. But the Pi does allow itself to use the 32bit 384KHZ option as it does do the extra processing so... (I'm probably answering my own question but I'll go along with it just in case any boffins know otherwise) is there a benefit of the higher option with this dac or is it just using heat?
    Tannoyista.com
    Facebook
    Will do next time its on.
    Which wont be long lol
    Similar here
    I'm Josie.
    Thanks Grant.
    Ah... it must be whatever the original input sample rate is... Makes sense. I'm now getting below. So basically the processor is working doubly hard as it's 24bit hardware hence a higher temp.
    Audio information Input Processing
    Source: USB/Music Drive 1TB/Rock/Queen/Queen - A Kind of Magic/01 One Vision.flac
    Encoded at: 16 bit, 44.1 kHz, Stereo
    Decoded to: 16 bit, 44.1 kHz, Stereo
    Rate: 762 kbps
    DSP Operations
    Resampling: 32 bit, 384 kHz, Stereo (soxr very high)
    Chip options: FIR interpolation with de-emphasis, aVol=0 dB, aPbb=.8 dB
    Volume:
    Output Stream
    Format: 32 bit, 192 kHz, Stereo
    Rate: 12.288 mbps
    Audio Device
    Device: IQaudIO Pi-DAC+
    Chip: Burr Brown PCM5122
    Interface: I2S
    CPU: armv7l, 900 MHz, 16%, 45°
    Tannoyista.com
    Facebook
    I'm Josie.
    So I'm guessing the Pi3 would find this process easier as there is a little stutter at the start of each track.
    Tannoyista.com
    Facebook
    So seeing as it only goes to 32/ 192, ive set mine to that.
    I'm Josie.
    Same here, Grant. It makes sense to keep processing down.
    Are you running a Pi3?
    Just wondering if the higher output rate would become available due to the faster CPU?
    Tannoyista.com
    Facebook
