Coming this way soon.
Intended to be the mate of a tasty STA25. Intention is for purity of sound through minimal signal path = as few components as necessary. Lets just call it the RFC-PP25 for now
Starting points:
1. looking at the input sensitivity of the '25 = 750mV for full output.
2. Assessing output impedance and coupling capacitance of source drivers.
In my case, worst case = 600 Ohms
Next stage: Type of passive.
I'm not a fan of TVCs as they can introduce as many issues as they solve and I just think they're unnecessary (with no further need to justify that statement which is my personally held opinion).
I want a means of balancing output to account for room effects, so some form of balance is desirable. I also require minimisation of any risk of ground loops and the case must be strong enough to support the STA25
Answer:
Screened case, large enough in area and strong enough = milled alloy frame.
Sufficient inputs and a decent selector switch with each input individually earthed (no common earths to be used) as this ticks the minimising ground loop issues.
Quality volume pots, one per channel. This remove the need for an extra components (balance control) in the signal path and also means that one can precisely tailor balance.
Captive outputs...no RCAs needed as the pre will be designed to sit under the power amp so I will hard wire the output wiring.
Volume pots selected are the excellent Tocos Cosmos pots. I have selected 50K pots which may be marginal with the STA's 100K input at 1/4 value (ie -6dB) but should, in reality, be ok. This will provide sufficient load for the source...I hope! The coupling capacitance of the source is large enough to pull down any high pass issues to well below audible threshold so bass shouldn't be compromised.
Selector is a cheap and cheerful one for now, just to test the control unit. If it proves a hit, it will be upgraded to something better quality. I will be using make before break switches to avoid any unwanted pops and crackles.
In the event that a different pot value is needed, I'll try it, and in the event that doesn't work, I'll revert to a buffer design for that particular source. Suck it and see time.
Photos to follow.
