I tried to solve this exact problem, first with an Rpi (there is a lag on AirPlay), then with a chrome cast and couldn't solve it. I got sick of faffing in the be and bought a really long optical cable. I am interested to see how you get on with the neet
THIS is supposed to do it but ive not tried as that was not my desire at time.
I tried a couple of them but couldn't get it to work. I might try again.
My delivery of the Neet is due late next week , I'll report back then.
Came at lunch today (Amazon delivery)
Plug into mains , ethernet cable into Router , toshlink into DAC.
For PC - supported platforms are Airfoil , itunes and Windows Media Player.
Downloaded trial Airfoil.
From Airfoil select source , Spotify then Musicbee both worked , so then bought Airfoil (£27).
25 mins job done and sounds great
Some more comments.
Airfoil is excellent , you can play anything from your PC if the app isn't supported you can just choose PC sounds as your source.
The Neet Wi-Fi reciever has just one small issue as do all recievers I've seen , they only have Toshlink out and the cable only supports up to 48kHz. Haven't found one with a Digi Co-ax out.
