Deck feet ID and isolation advice
I have a set of these sorbothane feet fitted to my deck can anyone ID them please?
the deck stands on a TNT flexi table made out of 15mm mdf I then have sorbothane pads under a sheet of acrylic and the deck is mounted to this. Has anyone used acrylic and a slate slab in tandem to mount there deck ,Would it be worthwhile using spikes and sorbothane feet in a combination ?
the reason I am asking is if I tape the mdf top shelf I get a thud from my speakers .
So if anyone had any experience or advice would be greatly appreciated.
Gerry
- You may not post replies
- You may not edit your posts
Forum Rules
