Hi all.
I'm sure someone here is using an SSD drive with their PI. What I want to know is are the SSD drives ok without an external PSU? or would I still need a PSU?
Thanks
Jo
Hi all.
Thanks
Jo
Tannoyista.com - Audio Equipment Reviews
I have a couple of SSD drives in My 'puter.
Both my drives have power feed plugs/require Power.
That said one can easily buy ~120 gb flash drives for Cheap (ish) Shops even stock 250gb ones , not so cheap though (today)
Being USB gizmos these don't require a dedicated /additional power supply
That's what I use with my Pi, 2 250Gb USB memory sticks. Works well, no problems.
ah... ok, thanks.
So, just wondering here.. are they easier for the pi to power than a conventional HDD?
Definitely, I've only managed to get an independently powered HDD to work, couldn't get a USB powered HDD to work.
I'm Simon.
I use a 500gb SSD with my Pi. I've ran it from the Pi fine but I decided to run it through the Pi USB hub just to be sure there are no power issues. My external enclosure has a 5 DC in too so can power it from that also.
A pi hub would run it fine... I am going into ssd territory with one of my laptops, going to fit an internal hybrid. If its successful i may move to externals too
I like simon,s idea of running an ssd off a hub anyways. Keep it clean and the less work the pi has to do the better
Cool.. that sounds like a plan.
Many thanks guys.
Ram chips typically run at 1.5 v. unless into overspeeding them :-).
Likely SSD and Flash drives also do so...given they are essentially repackaged RAM chips
Just How many GB's does one actually need? Even 128 gb is a helluvalot of Files.
Likely more than one would prudently trust to One (inevitably Failure prone) storage gizmo
